Sunnyvale, CA
I have started a new post to allow the 22 extra pages to go away! All the info on page 22 is copied and pasted here. Please up date any missing times before old post gets too far gone. To up date with a new ET, just click quote on this post, then add your et and info in the proper order of the post, remove quote brackets, hit submit.
6.402 @ 206 .952 60' 4.09 1/8 171 2001 bos R.E.D. 528 B-1 W/871 Koffel's Place Lake Erie Monster 6.69 @ 207 Allen Johnson, 2005 Dodge Stratus 500ci PS Hemi 6.49 1/4 4.45 1/8 1.03 60' 85 ss 526 blown alan johnson hemi gator(jerry Farmer va)
---7 second Zone --- 7.04 @197mph Tony Raffin, 03 Avenger, 645 Predator Headed Hemi 7.16 @206mph Mike T, 15psi of boost, TwinTurbo Daytona, 7.21 @ 193, 1.11 60', Hemifred, turbo Road Runner 7.41 @ 180.01, HMcCandless Jr, 540 indy, dragster. 7.68 @ 179.31, 1.08 60', 572stealth, '92 Dodge Daytona 572 B1MC, torqueflight, 2330# 7.78 @ 177.63, 1.10 60', PlumCrazyCharger, '68 Charger, 561 B1MC, 1.80 PG, 2680# 7.91 @ 181, 1.27 60', valiant65, 65 Valiant, 3319#, twinturbo 353B1BA + lenco 5-speed 7.92 @ 173, 1.15 60' ,70 Cuda 3150# 500 inch Larry Morgan hemi torqueflite 7.95 @ 168.56, 1.173 60' 408 cubes, Indy headed, fuel injected on alcohol,slingshot383
---8 second Zone --- 8.02 @ 174+, The Haze, twin turbo 452", 8.10 @ 169, TS3303, 91 Daytona, 2470# 572 , glide, just motor 8.13 @ 168, 1.165, 412ci all motor, glide, Dodge Omni 8.14 @ 169,with fogger and plate,Leon Hudson, 65 Barracuda 8.15 @166.58, 1.16 60' with 383ci W8 all motor 91 Dodge Daytona 8.178@ 167.12, 1.139 60', B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.24 @ 163, 1.15 60', Rapid588, 93'Dodge Stealth, 2490#, motor only. 8.36 @ 164, JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005# 8.46 @ 160, Moore & Moore 70 Duster, 572 Wedge, Single 4, Glide, No Nitrous 2650 lbs 8.48 @ 160, sp6162, 80 Omni, 2170#, 500cu, Indy-1,/glide. 8.51 @ 157, hemi al588, 588 Hemi, single 4, '69 Dart, #3250 8.52 @ 156.4, 1.17 60',SB412DUSTER 72 Duster,5.33 @ 126-1/8, 4link B/half 2424# 412/W7 NO P/A 8.57 @ 161, W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350# 8.62 @ 157, TwinDick Racing, 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 3340# 8.68 @ 156, "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.76 @ 156 OUTLAWSSAA 1.25 60FT 3120# HEMIDART 8.77 @ 153.16, Gregsdart, 65 dart ,528cu 440-1, 3000#, 2780 den altitude. NA 6/26/04 8.78 @ 160.34mph Lenny Melton 1968 DART 3,540lbs 10.5 ET streets. This is areal street driven car. 8.78 @ 153.71 mph, Pittsburghracer, 91 daytona 499 rb 440-1 unported .690 roller 2400# with driver 8.781@ 155.13, 1.261 60', Hemifred SOX&MARTIN DUSTER 8.79 @ 151, 1.30 60', Bill_LBSR, 68 Dart #3400, Stock Suspension,BFG Drag Radial 8.81 @ 151.4, 1.268 60', STEFF, 70 Challenger, 526" B1, 3378lbs, 29.5 x 10.5 ET Drag, foot brake, ALL MOTOR 8.859@ 151.00, 1.264 60’,Mopar_Racer_99, 68 Charger 572ci 440-1 heads,2880# 2065 den altitude 8.902@ 148.53, 1.244 60', 1974 Beeracuda, 2870 lbs, 499/PG 8 3/4 8.908@ 150.40, 1.245 60', RT540, 69 Coronet, 2840#, 540" B1BS-727TF 8.92@ 148.3, MoparBilly, 70 Challenger 440/eddies, 2880#, 2 stage plate, PG-8 3/4 8.94 @ 150, 1.25 60', B1duster, 498-1, 200 shot, 3000lb, 4.56, 14.5-32s 8.97 @ 150.9 70dustmite440 70 duster 451 3300lb. lots of spray street driven homebuilt hotrod. 8.99 @ 152.00 1.39 60ft,572 Charger, pumpgas, 3850#, street tires, full exhaust, 125 shot
---9 second Zone --- 9.04 @ 147.6 Best Machine 512 B1BS 65 Coronet 3400lbs 1.26 60' 10.5W Foot Braking 9.08 @ 149.75, Megadart, 422" W5 headed sb, all motor, #2540 9.09 @ 148 Moore & Moore, 71 Cuda, 498 Indy Wedge, 2700lbs 9.100@ 149.51, NHRAMARK, 70 Duster, 3050 lbs, 540" Indy 9.14 @ 148, '86 DODGE CHARGER 515 CI INDY MOTOR 2700 POUNDS 9.14 @ 147, Renegade5047, 69 dart 470 cu in, P/G,2520 lbs. 9.16 @ 147.78, Bigcube '69 Dart , 2975#, all motor, Indy -1 557cid 9.17 @ 150, MR P BODY, 405ci, 2430# 9.20 @ 148, 9secondsatellite, '71 satellite, 499" w/ 350 hp nitrous, 3976# 9.22 @ 147.7 DusterDave '73 Duster, Blown 528 HEMI, DOT's 3380# 9.22 @ 143.53 511 cu in 1.31 60 ft '68 Barracuda 2905 lbs Stage VI Mopar heads All Motor Single 4 bbl 9.27 @ 141.6, 440Jim, 1.251 60', 5.837 @ 115.5, '69 Dart GTS 3160#, 511 CID NA, no roller cam, footbrake 9.33 @ 142, 1.23 60', 1BADLILCHARGER '81 Charger 2300#, 440/727w/brake, Eddys, 9.34 @ 144.97, TheOtherDodge,498, Auto, 3450 lbs, true 10.5 tires, through the mufflers 9.35 @ 144.66, Bad66, '66 Dart GT, 471 B1 stroker...,all throttle no bottle 9.42 @ 143.10 SSDA3426 1967 Coronet R/T 1.245 60' with the Rear Wheels.4170#'s with driver.Fiberglass Springs Ladder bar,32x14x15 Aluma-stars under the chassis(Stock Rear Frame)Leaving at 2800RPM Shift At 7200RPM,5.38 Dana 727 GrinerBrake County Line Racing Trans,501 Indy Headed RB Single 9375-1050 Dominator carb.ALL THROTTLE NO BOTTLE. 9.41 @ 148, hemitime,'66 Dodge Charger, 549 Hemi,4020# stock susp, 100 shot, True 10.5 tire 9.42 @ 143.10 SSDA3426 1967 Coronet R/T 1.245 60' with the Rear Wheels.4170#'s with driver 9.43 @ 126, sloride, shutoff @ 1000', 70 cuda 572, Indy's 3500# street trim w/225 shot, 9.99 @ 136 on motor 9.47 @ 142.56 SSDA3426 1967 Super Stock Dodge HEMI Coronet.1.26 60' With Rear Wheels,32x14x15 GOOD/YEAR Slicks(under chassis stock Frame and floors/chassis).4170#s with driver.439.6 CI SUPER STOCK LEGAL 426 HEMI.Launch at 2400RPM shift 8200RPM.County Line Racing 727 Trans with Griner Gen III Billet Brake.THIS IS A TRUE HEMI SUPER STOCKER!! 9.48 @ 140.08, 1.270 60', SKR8PN, 93 Daytona 470,3000#,ALL MOTOR, street tires, mufflers w/ POWER WINDOWS!! 9.513 @ 139.32 Dartsport505, #2755, 505cu.in. 1.283 - 60-foot 9.57 @ 139 4404Dart, street car, 3300 lbs, Modern cnc heads, small shot of nos, 7500 ft DA. 10.50 on motor, 8 3/4 by dr.diff. 9.582@ 140.82 Eric, 81 Arrow 2354# tired 440 SR motor..:) 9.59 @ 142, Biginchmotor, 72 Barracuda, 3000#, 500 , 727 no trans brake, super stock springs, 4.30 gear 9.61 @ 140.55, HEMI71GTX... all throttle no bottle, 500ci, 4link, PG, 3075, 4.56's, 440-1's, Megablock, 3075# 9.61 @ 138, acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire 9.72 @ 137.9, a10sec70cuda, '70 hemicuda, pump gas 3800# street car, ALL MOTOR, drag radials 9.79 @ 137.6mph,W8CUDA71, 415w8,3308lbs,leafsprings! 9.82 @ 135.89, Mopargilley, 68 Barracuda, 400" W-2 motor 3170# stock 727 W/brake 4:56gear 11.5 tire 9.83 @ 135 1.31 60ft,493JOHN 3315#,493,pumpgas,no adders, drag radials,street driven. 9.84 @ 134.90, Bumps440. 69GTX 3240#, all motor, 446ci, stageIV iron heads, Footbraker 9.85 @ 135 398-W2 Duster398 9.85 @ 132.2, DCI, 38 Simca 225ci Slant 6/904, 1/8 6.10 @ 109.8, 2315#, Turbo, 12# boost, EFI,Methanol 9.86 @ 137.95, maxwedgemandra63, 1.35 60 ft', 1965 dodge coronet 557 CI stroker 3104 lbs 9.89 @ 136.42, ProSport, 73' Dart sport, 451, E-heads, 727, 1.37 60 ft, 3035#, all motor 9.91 @ 142 mph,440 906 heads, Mrsixpak 9.93 @ 132.97, moparjohn, 1970 GTX 3250 lbs car and driver at 700 air density Route 66 Joliet 9.94 @136.2, 1.43 60 ft,Cudabin, 67 Cuda, 470, Indy-1's, 2,870#, 727 Dana 4.56, 10.5W-31 9.94 @ 133.99, b3422w5, 70 duster, 422w5, 3380#, 727, leafs 9.952@ 131.56, 1.350 60', Sleepyhead416 73 Duster W-5 416 904 Dana 4.88 Ladderbar 2880 lbs 9.96 @ 134, DavidDean, 71 Duster, 5500'DA 413" 904 SB 2850# 6.18 @ 109 1/8 3500'DA 9.97 @ 133.88 340RICK 70 Challenger 416 W5's leafs and street tires all motor 9.978@ 134.24, 1.360 60'(1Bad440)70 Challenger streetcar,footbrake,leafs,Dot's 3460lb .060 440 stock stroke all motor [Email]9.983@133.89[/Email], ChallyL427 440 .055 over w/EZ heads by MCH, ATI convertor, Straightline cam at 3450. '72 Challenger footbracking all motor. New best coming soon! 9.994 @ 131.63 1.351 60 ft. (RBDuster) 73 Duster 446 9.995 @ 131.57 1.36 60ft (max-maniac) 64 Dodge MW on leaf springs and 9" slicks. 3250 w/me in it.
---10 second Zone --- 10.007 @ 132.3 / 6.35 @ 106.72 / 1.401 60' Lic/Tagged 66 Coronet NA 493 (#3740) on 9"ers .018 @ 131.09, almost in 9's 10.03 @ 135 through exhaust on dot tires paul swigart 69 pro street cuda 10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400 10.0714 @ 131.27, 1.366 60' ftbrkn Dustinu 396W5 @3300# 71 duster 10.073 @131.42, 440PURSUIT, 1.375 60' 10.08@ 133 BigGreenDodge, 64 Dodge 440 10.08 @ 132, 1.43 60' 64 Dodge (wildcargo) 10.088@ 137.53, 1.556 60', Tig, '74 Challenger, 528ci, Indy -13 heads, 3892# W/D, N/A. 10.09 @ 131.97,Thumperdart,1.41 60 ft,72 dart 3200+, home port Eheads 10.097@ 131.5 J-BODY 498 stage VI Mirada 3380lb 10.14 @ 129.70 70 Challenger 040 over 440 eddie heads .footbrake. 10.19 @ 128 1.32 60FT 10.5 tire 3660LBS John Cope CRT 63 Dodge push button T-brake 10.19 @ 129.63 1.395 60 ft, andradaracing 1970 dart. 3000 lbs w/o me. NO-Transbrake. 10.19 @ 136.77 1.41 60' footbrake Indy head EM block 511 lowdeck Mark Gates, AMC Pacer NA 10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA 10.22 @ 132.16 1.477 60' 74 Duster PRH446 Street tires through the Muffs 10.22 @ 131, 1.36 60ft, BigFish69, 440 Cuda 10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet cam 10.24 @ 128, 1.36 60', 10sec440, 440RB 452 heads 590cam pump gas 3400# 10.32 @129.01 1.45 60' DaveS 73 Swinger 446 E-heads, Mega-Squirt EFI SS springs Staightline Perf. Cam 10.325@ 128.36, 1.405 60', weedlayer, ugly year, sb Challenger, 3430# 10.33 @ 130.00, 1.52 60' Bubba, '80 Mirada, 440, 3630# 10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5" 10.43 @127.23 wyoming, ran at Vegas 4010' density air, 64 Savoy, 493 max wedge 3510 lbs 6.379 @ 107.24 10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor. 10.49 @ 128 1.45 60', TC67CUDA,500cid,w/E heads thru mufflers street car on DOT's 10.50 @ 129 KOS Nick 70dart driven to the track,trw flat top,stock rod 446,iron indy head 1050dom 3500#. 10.50 @ 126.68 1.40 60' dustyswinger 73 duster 416sb pumpgas ported cast iron smogger heads 3250# all motor 10.50 @ 127.00, daron 73 duster, sb street car 10.52 @ 130, BB70DUSTER, 400 stock bottom end w/ E heads on squeeze, and on pump gas 10.53 @ 126.64, 1.64 60', Jeepmon, '73 Duster 410 CI Small Block, 727, 4.10, 3400 full street 10.54 @ 124, 2933lbs 590cam,1968 dart 365ci mildly ported iron heads on alcohol Dare dude 10.58 @ 126.78,1.528, T748, 68 Dart 493 w/MCH CNC Eddies 10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads 10.64 @ 124.50, 1.49 60', RVA, 440ci 3165# 10.649 @ 126.45 1.510 60', BBLM23, 69 Dart, 3305lbs w/driver. Street tires, mufflers. 10.65 @ 123.43 1.45 60ft,11secdart 68 Dart,3160lbs,crate 360 W2 heads,904,s/s springs,10 1/2 inch slicks,mufflers, 10.66 @ 126 Mr. Belvedere, 66 Belvedere 470, 3725# 10.66 @ 124.84, 1.51 60'3800lb 67 GTX, 512ci.,s/s springs, dana 60, 4.10 gears, jkgtx 10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust 10.68 @ 125, 10secGTX 67 GTX 3670# 10.69 @ 126.46, MFR440, '65 Coronet, 446, Max Wedge, Beachy Eng, A&A Trans, 1.50 60', 3535 lbs. 10.76 @ 124, Mopartony, 68 Dart 470cid, 727 10.77 @ 123.9, 69Dart,1.49 60 ft, 3100 DA 10.78 @ 124 w/ 1.53 60ft... 72Challenger, 4211lbs Challenger w/ 528Hemi, STREETCAR 10.80 @ 124.86, gj69charger, '69 charger, 500cid 10.80 @ 123.1, 1.48-60' , ftbrke, 99.35@ 1/8 mile, Hemiallen, '66 Charger, ~3550# w/ his son Michael driving- not tuned-ootb eddy's-446-trw-sixpac rods-13.3:1-110 octane-shrt-shftd 727 ! 10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off) 10.89 @ 125.8, sunroofgtx, 71GTX, 472 Hemi, 4080# 10.92 at 130.2 1.69 60' Hemi Joel 67 GTX 496 Hemi 4 speed Stock Appearing, F.A.S.T. legal on G70-14 bias plys 10.98 @ 125.98, 1.54 60' 472 Hemi, 71 GTX 3900# SUNROOFGTX 10.98 @ 120.97, 1.48 60', TonyS451, '65 Coronet wagon, pump gas 470" street cruiser, 4020#
---11 second Zone --- 11.01 @ 122.38 , 1.57 60', 493Charger, 68 Charger R/T auto. 493" 3750# w/o driver 11.09 @ 118.95, 1.47 60', D.SLOAN, 395" SB in a 3250 lb. 69 Cuda, pump gas.. 11.17 @ 120.56 1.56 60' super451b , 70 Superbee 383 , 3460 lbs. 11.18 @ 123, 1.51 60', fast68plymouth, 68 Satellite, 383, stock 906's, 3550lbs 11.19 @ 122, G-bob, 1.64 60', 3650 lb 67 Coronet 11.21 @ 118.75, 1.55 60', DusterW2, 340 W2, 904, 3165#, 10" tire, SS Springs. 11.23 @ 118 1.53 60', 68DART360, 904, 3200 lbs, eheads, pump gas, full exhaust, 10" tire, ss springs 11.24 @ 119.3, 1.58 60', ZIPPY '69 GTX Street Car, 451CI, 11.26 @ 120 mph gmeater, 1968 dodge charger, 440 3700 lbs 11.33 @ 118.9, 1.60 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 stroked smallblock w/ factory J heads, solid cam and pump gas 11.346 @ 116 1.482 60'7.132 1/8 StipeHOG 440cu.in. 10.1comp 3300# pump gas 69 Dart 11.35 @118.49 Runner 71 roadrunner 452" ootb e heads comp xe282s cam 11.37 @ 122.19 1.808 60' 67 Charger 383 ironhead RemCharger 11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3700#, 2.5" exh sys,pump gas, 3.91, auto 11.40 @ 119.18, w2_360duster, 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020# w/o driver 11.43 @ 119 1.65 60' 440FISH 72 Demon 383stroker(454ci), 4000stall, 3.73, 452heads,hyd. cam, and fuel injection. 11.46 @ 115 1.55 60' Don1 75 Duster 360 3000# w/driver 11.47 @ 116.21 1.63 60' 340srule '70 duster full street trim 11.533 @ 116.32, 1.542 60' 6PKBEE 77 Aspen R/T 360/904/4.10 3425# 11.55 @ 116.23 , 1.62 , 60 , 383man's sons 406 Dart pump gas street car. 11.60 @ 116-69 superbee 440-6 pack-3800# BEEQUICK 11.62 @ 114 mph, 1.64 60' in a 3300# 69 fast back cuda street car...Phill 11.67 @ 116 RoadRnnr69, 1969 RoadRunner 500 stroker, auto 4:10 gears Street tires, full exhaust , 93 octane. 11.67 @ 116 mph, 1.71 60', 3800 lbs 71 Challenger, 446 pumpgas streetcar, rvoyles 11.702 @ 113.85, CudaDan, 1.565 60 ft, 360 auto 11.708 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears... 11.72 @ 113, 440Jim, '73 Cuda, 3700#, hyd cam, 446CID, street 11.76 @113.8, 1.588 60', 77 Volare, 400/727 3660# 11.78 @ 114, Sledgehammer, '71 Dart Swinger, 3470#, 366ci J-headed Small Block 904 Auto on street tires 11.84 @ 117.25 1.755 60` Scatpk 68 GTX 528 Hemi 4spd 354 gear 4175lbs w/driver 10.1 comp 242/242@50 solid cam factory intake TTI Headers 91 octane 11.84 @ 117.10 1.84 60', Jeepmon, '73 Duster 410 CI Small Block, 833 OD 4-speed street car 11.85 @ 116.6, 1.65 60', 68LAR, '68 Road Runner 3926#, 4 SPEED street car 11.934 @ 113.187, 1.67 60', 67Charger, '67 Charger, 440/727 (full man.), 4.10's, 3710# w/ me 11.91 @ 111, 1.634 60', topfueldart, 70 challenger 446, bone stock 906's, hyd cam psyco goofed.
---12 second Zone --- 12:001 @ 110.07, 1.61 60', Slantzilla, '66 Valiant post car, 232 ci Slant, Keith Long full manual 904, 3.91, 150 Top Gun shot, 3250#, Street legal. 12.02 @ 110, 1.58 60', cudadan 12.03 @ 111, 1.72, '66 Fury, 446/727, Edelbrocks, 3800 stall, 4:10's, 3960lbs w/driver Sportfury440 12.07 @ 108, 1.72 60',3250 lbs, Mikesduster, 72 duster, 340, street trim 12.17 @ 108, 1.77 60', dodge_nut, 71 Charger, 440/727 12.19 @ 105.88, 1.595 60', quickd100, 7.621 @ 87.04 1/8
12.24 @ 115 1.59 60' SSDA3426 1968 Barracuda Full Street Trim,340 with .030 10.1 pistons Stock X-Heads, 727 Cheetah Man Rev V.Body,Hoosier Quick-Time 275x60Dx15 Street tires,8 3/4 with 4.88 spool.This car is Street LEGAL & Driven.It has been a Deadly Competitive machine. 12.305 @ 112, 1.88 60', Jon Smith, 69 charger 493" full street trim, 7.94 @ 90 1/8 12.7 @ 107 69 M Clone 69 Dart 440/727/4.10 full street trim [Email]12.89@101[/Email] '75 Duster 360 stock pretty much with 340 hydralic cam, ATI converter and 3.91 gears. (mom's car) 12.95 @105.94, 1.94 60', PLATINUM6BBL 69-1/2 A12 Road Runner 3972# Pure Stock 14.025@ 96.08 BigGreenDodge, 72 Dart Swinger 318 Auto 79 d100 swb,318,284/484 cam,j-heads,4.57 sure-grip.9.34 at 75 in the 1/8.1BAD318
