6 second Zone ---
6.17 @ 216, .952 60'3.94 1/8 @ 178.6mph 2001 bos R.E.D. 528 B-1 W/14-71 Koffel's Place Lake Erie Monster
6.49 @ 1/4 4.45 1/8 1.03 60' 85 ss 526 blown alan johnson hemi gator(jerry Farmer va)
6.60 @ 209, Allen Johnson, 2007 Dodge Stratus 500ci PS Hemi
6.61 @ 210 Keith Jackson3775 Jerry Hass Neon 645 Preditor, Best Machine Power
6.85 @ 175, boatracer572, 572", drag boat
--- 7 second Zone ---
7.02 @ 196 mph 1.05 60' @ 2500# NOS 1 kit BOX68 . 7.84 @ 170mph 1.10 60' NA. 557 B1
7.16 @ 206, Mike T, 15psi of boost, TwinTurbo Daytona,
7.21 @ 193, 1.11 60', Hemifred, turbo Road Runner
7.41 @ 180.01, HMcCandless Jr, 540 indy, dragster.
7.45 @ 183 Go Green 547 B1 Procharger 1969 Barracuda.
7.48 @ 181, camastomcat, 2007 Yancer Dragster, 572" B1
7.51 @ 182, 1.10 60' ,1970 Cuda 3000# N/A Larry Morgan Hemi,torqueflite, Neverlift Chassis
7.52 @ 182.23, 1.08 60', PlumCrazyCharger, '68 Charger, 588 B1MC, 1.80 PG, 2810#
7.58 @178 ,1.049 60',alan prusiensky 05 stratus 604 ts
7.68 @ 179.31, 1.08 60', 572stealth, '92 Dodge Daytona 572 B1MC, torqueflight, 2330#
7.72 @ 173.98, Highway1, Dodge Avenger, 588 Indy Cylinder Head, w/ 175 shot off the start
7.83 @ 172, TS3303, Worthy Hardtail, 526 B1, NA
7.91 @ 181, 1.27 60', valiant65, 65 Valiant, 3319#, twinturbo 353B1BA + lenco 5-speed
7.95 @ 168.56, 1.173 60' 408 cubes, Indy headed, fuel injected on alcohol,slingshot383
--- 8 second Zone ---
8.02 @ 174, The Haze, twin turbo 452",
8.02 @ 169, Leon Hudson, Single fogger, 65 Barracuda
8.10 @ 169, TS3303, 91 Daytona, 2470# 572 , glide, just motor
8.13 @ 171, jyrki, 1.28 60', Plymouth VIP, C-body street car, DOT tire, 477 EFI TT, 3460 lbs
8.13 @ 168, 1.165, 412ci all motor, glide, Dodge Omni
8.15 @ 166.58, 1.16 60' with 383ci W8 all motor 91 Dodge Daytona
8.17 @ 167.12, 1.139 60', B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide
8.19 @ 166.54, 1.17 60', NoJoke, 2000 Dodge Avenger 2350lbs 512 832hp
8.24 @ 163, 1.15 60', Rapid588, 93'Dodge Stealth, 2490#, motor only.
8.36 @ 164, JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005#
8.41 @ 163, jyrki, 1.35 60', Plymouth VIP, C-body street car, DOT tire, pump gas, 477 EFI TT, 3670 lbs
8.46 @ 160, Moore & Moore 70 Duster, 572 Wedge, Single 4, Glide, No Nitrous 2650 lbs
8.48 @ 160, sp6162, 80 Omni, 2170#, 500cu, Indy-1,/glide.
8.51 @ 158 mph 1/4 mile, 3550#, SDCE 73 Challenger,sdce built 383cid stk blk and crnk, sdce cust D3M ProCharger kit, 4 link, full stk int. w/ backseat, all factory glass
8.51 @ 157, hemi al588, 588 Hemi, single 4, '69 Dart, #3250
8.52 @ 156.4, 1.17 60',SB412DUSTER 72 Duster,5.33 @ 126-1/8, 4link B/half 2424# 412/W7 NO P/A
8.57 @ 161, W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#
8.62 @ 157, TwinDick Racing, 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 3340#
8.663 @ t 157.19 1.255 60'Hemifred SOX&MARTIN DUSTER 10.5's
8.68 @ 156, "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650#
8.72 @ 154 Best Machine 65 Coronet 3420lbs 572 B1MC single 4 All Motor 10.5 X 29.5 (no wheelie bars)
8.753 @ 155.9, Mopar_racer_99 68 Charger,578ci 440-1, 2880# , 2640 den altitude NA
8.76 @ 156, OUTLAWSSAA 1.25 60FT 3120# HEMIDART
8.77 @ 153.16, Gregsdart, 65 dart ,528cu 440-1, 3000#, 2780 den altitude. NA 6/26/04
8.78 @ 160.34, Lenny Melton 1968 DART 3,540lbs 10.5 ET streets. This is areal street driven car.
8.78 @ 153.71, Pittsburghracer, 91 daytona 499 rb 440-1 unported .690 roller 2400# with driver
8.79 @ 151, 1.30 60', Bill_LBSR, 68 Dart #3400, Stock Suspension,BFG Drag Radial
8.81 @ 151.4, 1.268 60', STEFF, 70 Challenger, 526" B1, 3378lbs, 29.5 x 10.5 ET Drag, foot brake, ALL MOTOR
8.90 @ 148.53, 1.244 60', 1974 Beeracuda, 2870 lbs, 499/PG 8 3/4
8.90 @ 150.40, 1.245 60', RT540, 69 Coronet, 2840#, 540" B1BS-727TF
8.92 @ 148.3, MoparBilly, 70 Challenger 440/eddies, 2880#, 2 stage plate, PG-8 3/4
8.94 @ 151.1, 1.259 60', Bigcube '69 Dart , 2975#, all motor, Indy -1 557cid
8.94 @ 150, 1.25 60', B1duster, 498-1, 200 shot, 3000lb, 4.56, 14.5-32s
8.97 @ 150.9, 70dustmite440 70 duster 451 3300lb. lots of spray street driven homebuilt hotrod.
8.99 @ 152.00, 1.39 60ft,572 Charger, pumpgas, 3850#, street tires, full exhaust, 125 shot
--- 9 second Zone ---
9.04 @ 147.6, Best Machine 512 B1BS 65 Coronet 3400lbs 1.26 60' 10.5W Foot Braking
9.043 @ 145.96 Racebeeper68 - 70' Challenger R/T 501" wedge, 2805# 1.257'.
9.08 @ 149.75, Megadart, 422" W5 headed sb, all motor, #2540
9.08 @ 148.9 3404- '71 Duster 499" B w/glide 1.28 60' #2550
9.08 @ 149.6, MR P BODY, 405ci W-9, #2440, 1.21 60'
9.09 @ 148, Moore & Moore, 71 Cuda, 498 Indy Wedge, 2700lbs
9.10 @ 149.51, NHRAMARK, 70 Duster, 3050 lbs, 540" Indy
9.14 @ 148, '86 DODGE CHARGER 515 CI INDY MOTOR 2700 POUNDS
9.14 @ 147, Renegade5047, 69 dart 470 cu in, P/G,2520 lbs.
9.16 @ 147.6, DusterDave '73 Duster, Blown 528 HEMI, DOT's 3380#, street driven
9.17 @ 150, MR P BODY, 405ci, 2430#
9.17 @ 148, psycomopar 512 ci 3000# 72 duster
9.18 @ 145.1 with 5.81 eighth, 5.77 @ 118.1 1.26 60' 71 Duster 540 low deck flat tappet cam and glide motor only 2996 lbs 540dust
9.20 @ 148, 9secondsatellite, '71 satellite, 499" w/ 350 hp nitrous, 3976#
9.22 @ 143.53, 511 cu in 1.31 60 ft '68 Barracuda 2905 lbs Stage VI Mopar heads All Motor Single 4 bbl
9.27 @ 141.6, 440Jim, 1.251 60', 5.837 @ 115.5, '69 Dart GTS 3160#, 511 CID NA, no roller cam, footbrake
9.29 @144.02 SUPERSTOCKRACER 1.32 60 foot n/a footbraking 65 Dodge Coronet NSS/AFX with Cal tracs & monoleafs,588 ci with Indy 440-25 crossram and 3322lbs.
9.33 @ 142, 1.23 60', 1BADLILCHARGER '81 Charger 2300#, 440/727w/brake, Eddys,
9.34 @ 144.97, TheOtherDodge,498, Auto, 3450 lbs, true 10.5 tires, through the mufflers
9.35 @ 144.66, Bad66, '66 Dart GT, 471 B1 stroker...,all throttle no bottle
9.36 @ 141, 1.31 60', dafixr, '70 Duster, 2650 with me in it, 440 30 over, 906 heads, 150 shot, 5200 stall
9.38 @ 143.880, 1.34 60', 5.97 @ 115.997, Lil' Demon, '71 Demon, 3150#, 520 low deck, all motor
9.41 @ 148, hemitime,'66 Dodge Charger, 549 Hemi,4020# stock susp, 100 shot, True 10.5 tire
9.42 @ 143.10, SSDA3426 1967 Coronet R/T 1.245 60' with the Rear Wheels.4170#'s with driver
9.43 @ 126, sloride, shutoff @ 1000', 70 cuda 572, Indy's 3500# street trim w/225 shot, 9.99 @ 136 on motor
9.436 @ 142.51 , Eric, 80 Arrow 2354# tired 440 SR motor..:)
9.47 @ 142.56, SSDA3426, 439.6 CI SUPER STOCK LEGAL 426 HEMI.Launch 2400RPM shift 8200RPM, 727 w/ Brake, TRUE HEMI SUPER STOCKER!
9.48 @ 141.91, 80 AMX N/A 420 AMC Barry Allen racing engines Jerico 4-speed 10.5 tire street car 2950#
9.48 @ 140.08, 1.270 60', SKR8PN, 93 Daytona 470,3000#,ALL MOTOR, street tires, mufflers w/ POWER WINDOWS!!
9.49 @ 141.42, Jim DuFrain 1970 Duster,500", Glide, tube chassis, Toyo Slicks
9.51 @ 139.32, Dartsport505, #2755, 505cu.in. 1.283 - 60-foot
9.54 @ 140.4, a9sec70cuda, '70 hemicuda, pump gas 3800# street car, ALL MOTOR, drag radials
9.55 @ 141.25, 1.37 60 ft,Cudabin, 67 Cuda, 470, Indy-1's, 2,870#, 727 Dana 4.56, 10.5W-31
9.56 @ 139.17 moparjohn '70 GTX 493" CHENOWETH stroker all motor! 727 SPECIALIST transmission
9.59 @ 142, Biginchmotor, 72 Barracuda, 3000#, 500 , 727 no trans brake, super stock springs, 4.30 gear
9.61 @ 140.55, HEMI71GTX... all throttle no bottle, 500ci, 4link, PG, 3075, 4.56's, 440-1's, Megablock, 3075#
9.61 @ 138, acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire
9.63 @ 141, sp6332, 79 Arrow, 451, 727, 2550#
9.71 @ 138.9, Tig '74 Challenger, 3800lb, street car. All Motor.
9.75 @ 138, sixpakdodge, '82 Horizon, 440, 452/glide/4.10's
9.79 @ 137.6, W8CUDA71, 415w8,3308lbs,leafsprings!
9.82 @ 136, Dartman928, 74 Dart Sport all motor,pump gas, mufflers, street car, 28" by 10" tire
9.82 @ 135.89, Mopargilley, 68 Barracuda, 400" W-2 motor 3170# stock 727 W/brake 4:56gear 11.5 tire
9.83 @ 135, 1.31 60ft,493JOHN 3315#,493,pumpgas,no adders, drag radials,street driven.
9.84 @ 134.90, Bumps440. 69GTX 3240#, all motor, 446ci, stageIV iron heads, Footbraker
9.85 @ 135, 398-W2 Duster398
9.85 @ 132.2, DCI, 38 Simca 225ci Slant 6/904, 1/8 6.10 @ 109.8, 2315#, Turbo, 12# boost, EFI,Methanol
9.86 @ 137.95, maxwedgemandra63, 1.35 60 ft', 1965 dodge coronet 557 CI stroker 3104 lbs
9.88 @ 132, Irun6snd8th, 416 Stroker, Eddie heads 1.28 60ft 6.20 1/8th
9.89 @ 136.42, ProSport, 73' Dart sport, 451, E-heads, 727, 1.37 60 ft, 3035#, all motor
9.91 @ 142,,440 906 heads, Mrsixpak
9.94 @ 134.5 Glen440 70 Duster, pumpgas 511 with E heads, 727, ladder bars
9.94 @ 133.99, b3422w5, 70 duster, 422w5, 3380#, 727, leafs
9.95 @ 131.56, 1.350 60', Sleepyhead416 73 Duster W-5 416 904 Dana 4.88 Ladderbar 2880 lbs
9.96 @ 134, DavidDean, 71 Duster, 5500'DA 413" 904 SB 2850# 6.18 @ 109 1/8 3500'DA
9.97 @ 133, 1.38 60', sixpakdodge, '64 Dodge Sedan, 440, 1.76 'glide, 4.88's
9.97 @ 133.88, 340RICK 70 Challenger 416 W5's leafs and street tires all motor
9.97 @ 134.24, 1.360 60'(1Bad440)70 Challenger streetcar,footbrake,leafs,Dot's 3460lb .060 440 stock stroke all motor
9.97 @ 135, sgcuda, stock 440 shortblock except for Ross pistons, Herbert cam. 915 heads
9.98 @ 133.89, ChallyL427 440 .055 over w/EZ heads by MCH, ATI convertor, Straightline cam at 3450. '72 Challenger footbracking all motor. New best coming soon!
9.99 @ 131.63, 1.351 60 ft. (RBDuster) 73 Duster 446
9.99 @ 131.57, 1.36 60ft (max-maniac) 64 Dodge MW on leaf springs and 9" slicks. 3250 w/me in it.
--- 10 second Zone ---
10.00 @ 132.3, / 6.35 @ 106.72 / 1.401 60' Lic/Tagged 66 Coronet NA 493 (#3740) on 9"ers
10.004 @ 132.99 1.393/60 foot, dbran451
10.01 @ 131.09, almost in 9's
10.03 @ 131 1.45 60' Bubba - 3580# - Mirada
10.03 @ 135, through exhaust on dot tires paul swigart 69 pro street cuda
10.04 @ 135.13, J-BODY 498 stage VI Mirada 3380lb
10.05 @ 124, BB70DUSTER 1.43 60 foot 6.30 in 1/8th mild 440 on oxide, lifting early... 9s soon
10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400
10.07 @ 131.27, 1.366 60' ftbrkn Dustinu 396W5 @3300# 71 duster
10.07 @ 131.42, 440PURSUIT, 1.375 60'
10.08 @ 132, 1.43 60' 64 Dodge (wildcargo)
10.08 @ 134.2, 1.46 60', 66 Dodge Charger, 3700#, 493, ported EZ-1, 14.5:1
10.09 @ 131.97, Thumperdart,1.41 60 ft,72 dart 3200+, home port Eheads
10.10 @ 132.93. DC426, 1.40, 60ft, 72 dart 3200+, 416 SB, foot brake
10.14 @ 129.70, 70 Challenger 040 over 440 eddie heads .footbrake.
10.15 @ 135.65, 1.41 60', 6.46 1/8 mark gates 75 AMC Pacer Indy EZ's by PRH 511 lowdeck, 3650lbs footbrake/NA
10.15 @ 129.7, 1.40 60FT, Prochamp footbraking 346" W5 motor 3100 lbs.
10.17 @ 130, 1.36 60', 10sec440, 440RB Eddy heads, 590 Comp flat tappet. pump gas 3400#
10.19 @ 128, 1.32 60FT 10.5 tire 3660LBS John Cope CRT 63 Dodge push button T-brake
10.19 @ 129.63, 1.395 60 ft, andradaracing 1970 dart. 3000 lbs w/o me. NO-Transbrake.
10.21 @ 131.5, 1.42 60'. DaveS 73 Swinger 440 E-Heads EFI 3050lbs
10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA
10.22 @ 132.16, 1.477 60' 74 Duster PRH446 Street tires through the Muffs
10.22 @ 131, 1.36 60ft, BigFish69, 440 Cuda
10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet cam
10.28 @ 128.69,1.42, T748, 68 Dart 496 MCH CNC Eddies 3774#.
10.30 @ 130, 1.42 60', TC67CUDA,500cid,w/Indy SR heads thru mufflers street car on DOT's
10.32 @ 128.36, 1.405 60', weedlayer, ugly year, sb Challenger, 3430#
10.33 @ 130.00, 1.52 60' Bubba, '80 Mirada, 440, 3630#
10.34 @ 127.69, Cabs Duster 3400# on pump gas cork up, air cleaner on ET Street Radails
10.39 @ 129, (Tazmaniac/Shedevil), 446 906 heads 3400lbs 4.56 dana
10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5"
10.40 @125,1.40 60ft 68 Dart,365ci,W2,904,3150lbs,thru mufflers,foot brake"11secdart"
10.41 @ 128, 1.43 60' 73 Duster 3500# SB 416, Batton Heads All Motor, "El Picoso" Diego-Ted
10.42/130MPH stock block 8-71 10lbs of boost,4100lb car,dr.METAL STORM,69 SATELLITE.
10.43 @ 127.23, wyoming, ran at Vegas 4010' density air, 64 Savoy, 493 max wedge 3510 lbs 6.379 @ 107.24
10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor.
10.50 @ 129, KOS Nick 70dart driven to the track,trw flat top,stock rod 446,iron indy head 1050dom 3500#.
10.50 @ 126.68, 1.40 60' dustyswinger 73 duster 416sb pumpgas ported cast iron smogger heads 3250# all motor
10.50 @ 127.00, daron 73 duster, sb street car
10.53 @ 126.64, 1.64 60', Jeepmon, '73 Duster 410 CI Small Block, 727, 4.10, 3400 full street
10.54 @ 124, 2933lbs 590cam,1968 dart 365ci mildly ported iron heads on alcohol Dare dude
10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads
10.63 @ 125. 1.401 60', imin269, 395" SB PMPgas, N/A. FTcam, 275/60-15 DragRadial. 69 B-Cuda. Caltracs. Full exhaust to Fact. tips. Full Stock interior.
10.638 @ 127.67 Racebeeper68, 68' RR full mufflers, street legal, pump gas 1.550 60'
10.64 @ 124.50, 1.49 60', RVA, 440ci 3165#
10.64 @ 126.45, 1.510 60', BBLM23, 69 Dart, 3305lbs w/driver. Street tires, mufflers.
10.65 @ 123.43, 1.45 60ft,11secdart 68 Dart,3160lbs,crate 360 W2 heads,904,s/s springs,10 1/2 inch slicks,mufflers,
10.66 @ 126, Mr. Belvedere, 66 Belvedere 470, 3725#
10.66 @ 124.84, 1.51 60'3800lb 67 GTX, 512ci.,s/s springs, dana 60, 4.10 gears, jkgtx
10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust
10.68 @ 125, 10secGTX 67 GTX 3670#
10.69 @ 126.46, MFR440, '65 Coronet, 446, Max Wedge, Beachy Eng, A&A Trans, 1.50 60', 3535 lbs.
10.75 @ 122 73 Scamp 493 footbrake
10.76 @ 124, Mopartony, 68 Dart 470cid, 727
10.77 @ 123.9, 69Dart,1.49 60 ft, 3100 DA
10.78 @ 124, w/ 1.53 60ft... 72Challenger, 4211lbs Challenger w/ 528Hemi, STREETCAR
10.78 @ 124.30, 1.52 60' G-bob, 3625 lb 67 Coronet, 500" wedge
10.80 @ 124.86, gj69charger, '69 charger, 500cid
10.80 @ 123.1, 1.48-60' , Hemiallen, 66 Charger,3550# w/ son Michael driving- untuned-ootb eddy's-446-trw-sixpac rods-13.3:1-shrt-shftd 727 !
10.83 @ 124.3, 67 Charger 383 906 heads 3500lb small shot. RemCharger
10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off)
10.89 @ 128, 1.47 60', MikeCompTA 57 95 Firebird 350 n2o street car 3800lbs race wt.
10.89 @ 125.8, SunroofGTX, 71GTX, 472 Hemi,Dom. Drag Rad., Full Exhaust 4080# Street Car
10.92 @ 130.2, 1.69 60' Hemi Joel 67 GTX 496 Hemi 4 speed Stock Appearing, F.A.S.T. legal on G70-14 bias plys
10.93 @ 126.7, Orange Twist71, 451 street car
10.98 @ 124.24 Duner '99 R/T Dakota, 4046# turbo street truck
10.98 @ 120.97, 1.48 60', TonyS451, '65 Coronet wagon, pump gas 470" street cruiser, 4020#
--- 11 second Zone ---
11.01 @ 122.38, 1.57 60', 493Charger, 68 Charger R/T auto. 493" 3750# w/o driver
11.07 @ 119.52, 1.52 60', Vernmotor, 446 66 coronet 3500 w/o driver- pump gas.
11.16 @ 120, 1.58 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 smallblock, solid cam and pump gas Street Car
11.17 @ 120.56, 1.56 60' super451b , 70 Superbee 383 , 3460 lbs.
11.18 @ 123, 1.51 60', fast68plymouth, 68 Satellite, 383, stock 906's, 3550lbs
11.21 @ 118.75, 1.55 60', DusterW2, 340 W2, 904, 3165#, 10" tire, SS Springs.
11.23 @ 118, 1.53 60', 68DART360, 904, 3200 lbs, eheads, pump gas, full exhaust, 10" tire, ss springs
11.24 @ 119.3, 1.58 60', ZIPPY '69 GTX Street Car, 451CI,
11.26 @ 120, gmeater, 1968 dodge charger, 440 3700 lbs
11.27 @ 119, sp6332, 74 Duster, 340, 904, 2975#
11.29 @ 120.5 400BB, 727 3615lbs 77 Volare Glen440
11.29 @ 118, 1.55 60', 542gtx, 70gtx 542ci
11.312 @ 115.03, Locomotion, 360 Dart Sport @ 3,540 lbs IHRA Stock
11.33 @ 119.02, 1.64 60', 340_Dart, 70 Dart 416 w2 motor, 4.10's, 3400#, pump gas street car
11.34 @ 116, 1.482 60'7.132 1/8 StipeHOG 440cu.in. 10.1comp 3300# pump gas 69 Dart
11.35 @ 118.49, Runner 71 roadrunner 452" ootb e heads comp xe282s cam
11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3700#, 2.5" exh sys,pump gas, 3.91, auto
11.40 @ 119.18, w2_360duster, 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020# w/o driver
11.43 @ 119, 1.65 60' 440FISH 72 Demon 383stroker(454ci), 4000stall, 3.73, 452heads,hyd. cam, and fuel injection.
11.45 @ 117.73 , 383man's son , 400 Dart pump gas street car.
11.46 @ 118.46, 1.604 60', 67Charger, '67 Charger, 440/727 (rev. man.), 4.10's, 3975#, full exhaust
11.46 @ 115, 1.55 60' Don1 75 Duster 360 3000# w/driver
11.47 @ 116.21, 1.63 60' 340srule '70 duster full street trim
11.52 @ 116.84 , 383man's 63 Ply Max Wedge wanna be pump gas street car.
11.53 @ 116.32, 1.542 60' 6PKBEE 77 Aspen R/T 360/904/4.10 3425#
11.53 @ 117, 1.68 60', Bill Greenwood, 1969 Dart, 366 ci, ported j-heads, MP 528 solid, 904, 4.88, 904, 3200 lbs. 3300' DA.
11.54 @ 116.35, 1.69 60', Defbob, 71 Dodge Challenger Conv., street 511" with 3.55 gears, 3800lbs
11.57 @ 115.90, 1.60 60', TonyS451, 63 Dodge 440, pump gas 511" with HP exhaust manifolds and 3840lbs of 4 door fun
11.59 @ 119.64, 1.80 60' Gary67, 66 Satellite 440,auto,4:10, 346 heads, Holley 800.full exhaust,full interior..
11.60 @ 116, 69 superbee 440-6 pack-3800# BEEQUICK
11.62 @ 114, 1.64 60' in a 3300# 69 fast back cuda street car...Phill
11.67 @ 116, RoadRnnr69, 1969 RoadRunner, 500 stroker, auto 4:10 gears Street tires, full exhaust, 93 octane.
11.67 @ 116, 1.71 60', 3800 lbs 71 Challenger, 446 pumpgas streetcar, rvoyles
11.70 @ 113.85, CudaDan, 1.565 60 ft, 360 auto
11.70 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears...
11.72 @ 117.00, 1.62 60', 68LAR, '68 Road Runner 3926#, 4 SPEED street cruiser,
11.72 @ 113, 440Jim, '73 Cuda, 3700#, hyd cam, 446CID, street
11.74 @ 112.75, 1.58 60', jinxy, '70 Dart, 408"(x-heads)/727/4.10s, full body 3500# w/driver, pump gas, full exhaust
11.78 @ 114, Sledgehammer, '71 Dart Swinger, 3470#, 366ci J-headed Small Block 904 Auto on street tires
11.84 @ 117.25, 1.755 60` Scatpk 68 GTX 528 Hemi 4spd 354 gear 4175lbs w/driver 10.1 comp 242/242@50 solid cam factory intake TTI Headers 91 octane
11.84 @ 112, 1.70 60', Sportfury440, '66 Fury, 440, Ebrock's, MP 557, PTC 9.5", 4:10's, 3915 lbs
11.86 @ 110.27, 67 Satellite,w/ stock 906's and hyd.cam.8 3/4 with 4.10 gear and 3500#.
11.91 @ 111, 1.634 60', topfueldart, 70 challenger 446, psyco goofed, bone stock 906's, hyd cam
11.966 @ 109.52, 1.614 60' rmvduster73, '73 Duster 363 with stock J heads, 3275 lbs
--- 12 second Zone ---
12.00 @ 110.07, 1.61 60', Slantzilla, '66 Valiant post car, 232 ci Slant, Keith Long full manual 904, 3.91, 150 Top Gun shot, 3250#, Street legal.
12.02 @ 110, 1.58 60', cudadan
12.02 @ 111.4, 1.75 60'Duster3105
12.07 @ 108, 1.72 60',3250 lbs, Mikesduster, 72 duster, 340, street trim
12.17 @ 108, 1.77 60', dodge_nut, 71 Charger, 440/727
12.19 @ 105.88, 1.595 60', quickd100, 7.621 @ 87.04 1/8
12.20 @ 113.75, 1.77 60', MikeCompTA 57 2007 Charger SRT8 4400lb race wt.
12.24 @ 115, 1.59 60' SSDA3426 1968 Barracuda, Street Trim,340, 10.1 cr, Stock X-Heads, 727 Cheetah V.Body,Hoosier 275x60Dx15 Street tires,
12.30 @ 112, 1.88 60', Jon Smith, 69 charger 493" full street trim, 7.94 @ 90 1/8
12.37 @ 110.2,"MoparDonny" '71 Challenger, 440, 509 cam, 3.91's, Full street setup with 2-1/4 exhaust.
12.41 @ 110, Superb70, 70 Super Bee, 9.6:1 440 W/516's & .474,280 purple shaft ,manual 727 , 4.10 sure grip
12.43 @ 106.13 Triple Threat 67 Dart 340 904 3.91's
12.56 @ 109.19, 68 GTX 440 6 pack, thru exhaust, w/spare tire & tool box. Edlebrock RPM, .509 purple shaft, MT streets, 727 w valve body & shift kit, 3.91 8 3/4 rear
12.64 @ 104, sixpakdodge, '65 Coronet Sedan
12.7x @ 107, 69 M Clone 69 Dart 440/727/4.10 full street trim
12.78 @ 108.58, rick55, 73 Dart Sport 440/727/3.55 full street trim
12.89 @ 101, '75 Duster 360 stock pretty much with 340 hydralic cam, ATI converter and 3.91 gears. (mom's car)
12.95 @ 105.94, 1.94 60', PLATINUM6BBL 69-1/2 A12 Road Runner 3972# Pure Stock
12.95 @ 104.5, Shaker223, 1.89 60', Stock Slant 6 with turbo, 1970 swinger, 2.94 gear,
-- 13 second zone ---
13.01 @ 107.93, 70sixpkrt, 70 Charger 440-6pk 4-speed with .007 R/T;2.08 60', BFG T/As spinning off the line. Spare tire and coolers in the trunk.
13.02 @ 101.10, RangerDan440, 1.90 60' 2500' elevation '68 Coronet R/T #'s 440 .509 cam, mild port 906s, Holley 750 DP, TM7 intake, MSD 6 AL, 4 speed, Hayes clutch, 3.54 Dana, 28" Drag Radials
13.17 @ 102.7[Still down on mph), - Moparmal - stroked 318(349), Comp Magnum 282s cam, Firehawk radials
13.74 @ 96, sixpakdodge, '72 Swinger, 318/auto
