Running no stat, the water passes throw the radiator too fast, not disapating/exchanging heat transfer,.....so you could actualy run hotter,...
I don't believe people still believe this old wives tale.
I used to post and post about how this is not true. I finally gave up. The only way it could possibly be true is if without the stat it created cavitation sufficient to slow everything down. I don't think so. Kim
