1973 cuda, originally a 318 3 speed, but original motor and transmission were missing so I installled a 340 and a 4 speed. Car originally is JA5 silver frost metallic with black side stripes. It has been sitting since 1982 and has 81,432 miles on it. At one point in its life the car was converted to an automatic and had a sunroof installed. I have since put the 4 speed back in. It used to be my dads car, he bought it as a rolling shell back in the early eighties and parked it after he bought it and it has sat there ever since. I rebuilt the motor and put in a Comp XE268 cam, Edelbrock LD340 and ported 2.02 J heads. I plan on putting the 4" stroker kit in it down the road. Ive been restoring it since May 2006 and it is currently at the body shop to have the roof replaced, new quarters, trunk floor, extensions and to get painted. Body is pretty solid on the car, quarters were patched in the past and I only had to put a floor pan in on the drivers side.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
