Re: Part # for '71 e-body turn sig. switch?
[Re: NachoRT74]
#338569
06/10/09 02:30 PM
06/10/09 02:30 PM
Posts: 2,592 None
71rm23
None
I haven't looked at them under a magnifying glass, but one obvious difference is in the wording on the knob. 3488805 - Hazard 3488477 - Flasher
71rm23... yes, as stated by 472 R/T SE, you can find aftermarket pieces cheaper than pentastar pieces that works the same, just some diff colored wires and plastic parts. REALY REALLY if you ask me the correct Pentastar part will be the 3488804 unit, since thats is the one without conrering lamps, BUT is not available as new Mopar replacement parts, just NOS. So 3488805 ( if not aftermarket TW7 ) will be a replacement part, but without use the cornering harness.
Thanks Nacho. Sorry if I'm not clear on one thing..Are you talking about the front side marker lights in refering to "conering lights" Thanks again
