Recurve the distributor to get all the timing in as early as detonation allows.
run as much initial up to 1000RPM as you can (light springs) to build vac which will allow a wilder cam then monitor the curve. Stay on top of the detonation situation & you'll need lead for the non hardened seats (unless you've redone them). If it's not a claimer class you can sink as much money into it as you want and unless prohibited in the rule book ponder any mod that will get the most quality (homogenized) mixture in/out & good ign & lightened reciprocating assy. Out think em! and post how you do & how many furds/chebbys you beat
