I will say this again. If you use the line lock to "block" the rear brakes, PLEASE consider using a "dead Man" switch. They can be purchased in different styles : toggle, pushbutton etc.
This will make sure you will have rear brakes at the end of the quarter mile.
I orginally had a push on/push off switch on mine. I also wired an indicator light on the dash so I would know it was on. I still ended up forgetting to turn it off a couple of times and didn't realize it until I noticed the light on on the return road.
I now have it wired to a switch on on the shift knob of the hurst qtr stick shifter. Have to hold the switch down with my thumb to engage the line lock.
