In 2000 when your Grand Cherokee was new the +4 fluid hadn't come out yet. The original fill is +3. Now (at Chrysler) there is no more +3, you use +4 for everything. So the answer is you can use either. I think the +4 is a little more $$$. Hope this helps.
