Whoa whoa whoa....
If you are rolling along at 80 mph and the vibration is there...and you put the car in N and the vibration goes away...
would you not want to investigate the converter/flexplate/flywheel balance? If the driveline was causing this the vibrato would still be there even in N when the car is rolling. Personally I'd think about finding a different driveshaft shop. It is straight or it's not. If not it needs to be retubed or it will never be correct.
I do not want to investigate the converter/flexplate balance, but I might end up having to. I want to swap to a 4 speed anyway, so maybe this is the time to do it.
Thanks,
Scott
Please Check Out My YouTube Channel for Vintage Musclecar and Truck Rescues and Builds -- https://www.youtube.com/@THEBULLETPROOFGARAGE/videos
