Re: FIRECORE WIRES and radio noise????????
[Re: sunroofgtx]
#323988
05/27/09 12:13 AM
05/27/09 12:13 AM
Posts: 10,234 Someplace you aren't
SomeCarGuy
swapped out the firecore coil wire to the date codded supression wire and 85% of the noise is gone, i guess the rest of the wires swapped out will fix the noise. too bad the firecores fit nicely.
i guess Rick Gorski from Firecore will be glad when this post dies.
Why would I want it to die ? Chris, glad swapping out the wires worked for you. AM radio is cool. It's what I listen to half the time.Sorry I missed the post, but I've been at the racetrack a lot these days, and we are moving the factory into a new building. Too busy to be online a lot , anymore. I'm sorry the 8mm stock-looking wires don't work for you, Chris. We do have the in a 250 ohm, but thats another story. Good luck with cruizzzing, it really is a great-looking car.
So the 250 ohm would be better for radio playing but would it be noticeably different performance wise on the track or generally?
I want my fair share
