there is little to none side to side misalignment issues, the top comes down and lines up perfect the gap front to back turned out to be 1 1/2" by clamping a piece of angle iron to the inside it brings everthing to where it needs to be Ron,,
and yes I had just came back from harbor freight with a mini saw and a cutoff grinder right befor we cut the top off
