Would it be reasonable, if I found a complete salvage RAM coil over suspension cheap, like less than $500. Would it be reasonable to weld the RAM suspension mounts onto the rear axle from my 2001 Dakota (3.55 ratio, drum brakes, semi-posi) so it would fit under my 56 frame build.
My 56 C3-B8 Dakota build
