This.....
"First thing to do is have you water tested and see how many grains of hardness you have. if you are above 7 or so you could benefit from a softener. Then you will need to size it appropriately based on your grains of hardness and gallons used per day."
And like all things, they require maintenance. I set a reminder on my calendar for maintenance times. up
My Monster are real!
Living within your means makes life pretty easy.
