The lifters aren't the issue. It's rocker arms. The wheel/bearing/axle wears allowing the roller wheel to drop down. Then the truss portion of the rocker ends up rubbing on the cam and actuating the valves. If the valve train is quiet it's not a rocker/cam issue causing the miss. Most likely a coil or injector.
Doug
