Without knowing how much travel is left in the lifters the only correct answer is "maybe". In all honesty a .020 or .030 cut isn't going to gain anything. It's .0066" cut per CC of chamber, so .030 won't get 5 CC. You might get the compression up to 8:1.
IF my old brain remembers correctly, there SHOULD be about .090" of travel left in the lifters.
"Everybody funny, now you funny too."
