It makes the "turns out" adjustment different but, with the aftermarket servos, the 5/16" or 3/8" air gap adjustment will work with any lever. The length of travel of the servo effects shift timing so you want to keep it the same with all lever ratios.
The INTERNET, the MISinformation superhighway
