Originally Posted by volaredon
yeah this is the front band apply lever.
how would a 3.8/4.2 be better than a 2.5? would I adjust the front band "less turns out" from the 72 in/lb? I knew a guy at the dealer that never did the "X" turns out from 72... just watched the clearance but I forgot how much.
The higher the number the more leverage it applies , if it was working ok you could just leave it , what does the band you took out look like ??
running up my post count some more .
