Originally Posted by JohnRR
Originally Posted by dakotaman
JohnRR,
How do you tell if it is the cone type? I will google search it. I will probably pull the center section this upcoming weekend.
Who put the gears in it ? Now that the gears are setup it's not to hard to change out the diff , check current backlash setting and reset the backlash after you change the diff. You'll need new bearings for the diff.
Look at the link above , the cone type is the top picture , it is easily identified by the springs in the window.
I will add to check the back lash in 3 or 4 positions noting them on the gear, try to get as close as possible the the existing numbers wink
