I have a very limited supply of NOS OE correct and OE appearing windshield washer pumps. These pumps are correct for variety of applications, including 67-71 B-body and 70-71 E-body. I have several options available with regard to the angle of pump discharge and ground wire configuration. Some of these are NOS out of the box and others are assembled from NOS components sourced from assorted applications. All are tested and guaranteed to work as designed.
I can restore original ground wires or add new ground wires depending on buyer’s preference. I also have tooling to secure the ground wire eyelet to the washer bottle.
Pricing varies between $150-$250 depending on type of pump (Delman or McCord), part number, date code, ground wire, etc. Please contact me if interested and I will provide further details.
Thanks for the ad!
Link to a very detailed thread discussing correct 70-71 E-body washer fluid pumps: https://board.moparts.org/ubbthreads/ubbthreads.php/topics/265356/1.html
