But, it looks like something attached to the governor pressure tap. Never seen anything like it before.
Definitely looks like governor pressure line but what could they be using that for? Somehow tied in to cruise control or the speed governor on a truck?
The best guess over at the AMC forum is that it's part of the TCS (transmission Controlled Spark). That line goes up to a switch/solenoid that electrically controls something to do with spark advance I believe.
I'm just trying to understand if I can remove the line and plug for my use.
Kunkel, where are you at?
