Originally Posted by Cab_Burge
13 to 17 inch lbs. on used bearings, 20 to 25 inch lbs. on new bearing with the pinion gear pointed straight up per the 1970 FSM wrench I check them both ways, forward and reverse up twocents
Those numbers work well scope
Yes, same here. I set mine up at 18-20 no issues thus far several years on it street and strip.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
