Originally Posted by Cuda340
Also a 68 power-loc will have the one piece side gears, the earlier units had two piece side gears and you would have to use the axles to align the splines before tightening the unit back together after a clutch rebuild.
All the Dana brand 8 3/4 posi had two piece side gears, the later Eatons did not have clutches or the same type spider gears like the Dana 8 3/4 posi units had scope
If you can see springs inside the posi it is an Eaton type, not a clutch type Dana brand scope
