Have you tried flowing the head with the intake, and carb?
No I did not have time to do that yet would like to have that data but I would like to be on the dyno in 2 weeks(good luck with that LOL) and I still need parts..... and need to finish the other head and match up the intake. I will give it a shot(flow intake/carb on the head) What did you think of the flow #s ? This is now a 2.08" intake valve so if it did not back up over .650" would be darn nice head. I think it would make big power on all out Drag engine.
I would have tried a 2.125 valve. Did this on a project I'm working on right now, and it actually works quite well! Flow #'s look alright, but .400 and .500 are low compared to larger intake valve that I've tried.
How fast is the port where you are accessing (.100 below max lift at the valve measured)?
Brian Hafliger
