I belive this is the one for 1970 4-barrel cars (except Cali emissions which has 3 nipples IIRC)
That's what's on mine anyway!
Correct me if I'm wrong - because I don't have a dual snorkel air cleaner yet, but does one hose go from the breather to the back of the air cleaner housing?
Hooks up like this in 1970 on a non-emmissions car:
You will also need the "1970 only" valve covers to make it look completely stock if that's what you are going for. (They have the push-in breather grommet on the passenger rear, filler cap on the passenger front, and the PCV on the drivers rear)
Unfortunately, these VC can be hard to find if you do not have them, or you can custom drill yours like i did.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
