Originally Posted by Stanton
Wondering how the TTI system would fit using Doug's Headers ??
Also have the rear springs moved inboard so the pipes would have to run off to the sides of the frame rails - is there adjustment there to move them closer to the tank? (69 B-body)
The X-pipes have slip joints to allow adjusting the side-to-side spacing to fit the header collectors, so they're not header-specific. But that's the only adjustment in the system that I can think of. I'd contact tti to verify.
