The fan switch in my truck decided it no longer wants to work. It will work, on high speed only, when you switch it to A/C or heat, but you cannot control it from the switch.
I have been looking around to see if I can just replace the fan switch without replacing the whole thing, but no luck.
Suggestions or tips please.
My Monster are real!
Living within your means makes life pretty easy.
