Originally Posted by dvw
It'll more than likely be fine. If it breaks? A B body 8 3/4 is a bolt in using a factory 727 Duster drive shaft. the 81/4 brake parts will bolt up as well.
Doug
Not really, at least not without new axle shafts. bolt pattern and flange offsets are different.
Ran an 8 1/4 behind a warm 360 and an A833 in my Diplomat for years. SG with P255/60R15 BFG's. No issues
