Removal method is to roll the windows down and lightly bump them loose from the backside going outward and slightly upward along the bottom edge with a small block of wood as a drift punch. Might want to have a helper hold them so they don't fall on the floor.
The can opener method so many use can put dents/marks in them if you get in a hurry.
