In its first year Chrysler’s press release said the new 5.7 was
“6% more fuel efficient”
than the previous Magnum 5.9V8
a portion of that must have been no distributor drive
another portion 2 spark plugs per cylinder
another portion thinner piston rings
another portion higher dynamic compression ratio
That's rather humorous, in hindsight. My last Magnum-powered truck couldn't go 500 km (310 miles) on a tank. My first Hemi easily went 100-150 km further on the same size tank. The Magnum was undrivable in cruise control, as the O/D constantly hunted, even on a relatively flat highway. Hills the Magnum (318) couldn't get up in high gear, with NO load, the Hemi could go up in O/D, with a 3000 lb car on a 2000 lb trailer behind it. I'm now on my 4th Hemi truck. Two weeks ago, I rolled out of Kalispell with a full tank. Drove 65-75 mph all the way home. 665 km. The range indicator showed 224 km to empty when we pulled in the driveway. Same size tank as my old 318 Magnum, in a 4x4 Crew Cab 1500.
