I would drain both the radiator and block, both sides, and let it sit for the winter. I would pull all the spark plugs and squirt oil into the cylinders and then spin the motor over with the plugs out and then put the plugs back in and make sure to not start again until you put the coolant back in the motor wrench twocents up
