Since you have petcocks on the block I would drain and catch it so you can reuse it, I seen its $28 a gallon.... eek Flush the system out with water and fill with 50/50 antifreeze.
Repeat in the spring and put the blue back in.
I question just how detrimental it would be to mix regular antifreeze with it. Probably wouldn't hurt anything but at $28 a gallon I am running it through a filter and saving it.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
