mine had a 30 gallon saddle tank, went to a mustang tank mounted same as basketcase more or less.. IIRC i removed one of the frame braces for mine, gas gauge works but not accurate to scale but I have learned it over time E = 5-6 gallons bottom of E = empty. this may vary depending on size of your take and gauge. works great and helps with weight distribution and traction.
