One of the things i have learned works well with the big block pattern on the flanges is to add an upper and lower fastener between the two center exhaust ports. This spot was a constant troublesome area for leaks.I never used gaskets on the exhaust and had extremely minimal leakage after doing this. Look at the carbon trace on the head…
"use it 'till it breaks, replace as needed"
