With my 55MM roller cam bearing cam. I run Penn Grade 10W30 with a Melling high volume oil pump that I took apart clearanced, ported and polished. Also run bronze bushed lifter bushings with push rod oiling and the RBRE rocker system that has built in spray bars. Also a 10 quart Milodon flat bottom top fuel/funny car oil pan with Milodon external pick up. and a 3 quart Accusump (just in case). No issues on the street with hundreds of miles or strip.
