i pulled the carpet out of my 69 charger because i have a new replacement set. this is the original carpet, and although the car is just about to turn 19k original miles, the carpet has been deteriorating for many years. this is even while being a garage queen and not driven since at least 2006 or so.
while scratching the floor pan with a wire brush by hand to get rid of some loose paint and leftover horse hair backing material, i hit several sections of seam sealer, and it fell off in large chunks, like it lost it's adhesion. [which of course it did !]
i then used a hand scraper, and most of it came off by just touching it with the scraper. no effort needed whatsoever.
what was used back then, and what would be a good replacement sealer to use ?
TIA for the knowledge you folks have that i do not.
