I don't know what the MSD relay boxes are rated for shruggy the relays shown can be had up to 60A and higher if one uses a 5/16 terminal. At the larger amperages doe be careful on the source. IE: Bosch, hella or other well known brand
What are you trying to control and what is the current draw?
Also is the current draw continuous or intermittent beer
