Refreshing a Pro-Flite. Thought it might be interesting to see the guts. Nice parts for sure. It's a morph between 727 and 9904. Case, shafts, pump, and low roller are 727 based. Pump and case are modified to accept 904 drums, planets and bands. 6 pin planets, lots of billet aluminum goodies. Aluminum park gear. Servos are stock. I pull the VB apart to clean. Dave says he doesn't use fancy clutch frictions or Kolene steels.
Doug
