You would be pretty limited on off-the-shelf cams. (Probably none.) And the cams will be a lot more money. Roller cam bearings look sexy to me, but Sonny Leonard (and others) have told me that there's not a single horsepower to be gained. He said the only good thing about them is the engine is easier to turn over to adjust the valves.
2011 Drag Pak Challenger
