I looked at this car yesterday. I'm all over it. Really clean inside although it's been smoked in. The right rear suspension is knocked loose, the right front suspension is hurt, too. Needs a wheel and a couple of tires. Has creases down the right side that will fix without too much trouble. Side curtain air bags and seat bags are popped and the red belts are locked. The seats are actually the biggest problem.
I am not into these late model Challengers much, although I have a '16 V6 car now that I daily because it still has the XM active and gets almost 30 miles to the gallon. But this one just struck my fancy and if I can get a good enough buy on it, I'M IN!
It goes through this afternoon. Just for fun, how high would you go on this one?
www.copart.com/lot/48962253
Master, again and still
