It's been a long time so please forgive my memory. But if you use the Green bearings the thrust buttons, or block, wasn't needed correct?
I am pretty sure the 8.75 I run has the axles lengthened for full spline engagement with the buttons removed.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
