I am still wondering if anyone has ever successfully used the Trick Flow 240 heads combined with an original max wedge intake (440 port size)?
I have the same intake bolted on a motor with edelbrock heads.
Should be same deal with 240 heads. Both standard port.
You should have no problem at all.
I haven’t called A&A to confirm but I was under the impression
it’s the same casting for both standard port and max wedge port.
I assumed it was like the Indy modman, they only cnc the port opening to max wedge size, extra $100.
But I’m not sure and you know what happens when you assume.
