Originally Posted by moparjim79
Tape or dope is fine. Use both sparingly. Never a problem here, both iron and aluminum intakes...
I agree.
The teflon tape & pipe dope fills the gaps in the threads but when you tighten the sensor down you will get metal to metal contact through much of the threads.
