You need to do a starter draw test to see how many amps the starter is drawing,it could be the starter on its way out,just guessing i would think any draw when cranking,should be less than300amps.
Advance AP has a tester that checks the battery w/o load, starting and running, charging also. Stop by one of them. I'd think the other stores would but don't work at them
