Originally Posted by moparx
but if you don't take that stuff frank and doug are hawking, you won't get the babes rushing to ya ! biggrin
i have been tested for T many times, and it is right up there, so that issue is at least known.
and besides, a person NEEDS everything advertised on tv ! the add say so ! laugh2
beer
I think some of their commercials are approaching something the FDA should ban. Some of their claims, despite the fine print, shouldn't be allowed IMO. I hate to think of all the people spending money on this stuff when it probably doesn't work AND they may not even need it in the first place.
it used to be you went to your doctor when something was wrong with you, he did the examination, had blood tests done if necessary, then investigated the results and using his best knowledge, prescribed any medication he thought might be best to get you fixed up.
along came "change" allowing drug companies to "advertise" on tv and other media [mostly magazines, as the interwebs were not up and running at that time] and suddenly, "tell your doctor you need [insert drug of your choice here] !" so now the patient is telling the doctor what is needed to treat his ills just because a drug company add tells him this will work ?
good grief ! runaway
beer
I wish they'd ban parmas from advertising! They also say "tell your doctor if you have........" and go through a list of ailments that prohibit you from taking their drug.
Facts are stubborn things.
