I am going to use an external single line milodon on the new engine with the swinging pickup (block one of the lines). I am wanting to run some kind of filter between the pan and the pump and have noticed you can pick up a used Oberg filter pretty cheap. I was curious if the Oberg filter had to be mounted or can it simply dangle between the lines. I run my fuel regulator dangling and I have convinced myself it aerates the fuel less now.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
