Fel Pro 1462 header gasket on the driver's side. Just high temp silicone on the passengers side. I also like the TTI header gaskets. I use the bolts that came w/ the TTI headers.
The reason I use a gasket on the drivers side is b/c the header is sandwiched in there when the motor is dropped in...can't get room to put silicone on it. Much easier for me to just use a gasket. The passenger's side header will fall out from under the car when you unbolt it. Fairly easy to silicone it and bolt it up.
