Originally Posted by 493_DART
Originally Posted by B3422W5
Fuse box on those years is notorious for wierd issues with lights, turn signals, etc
Funny you mention that...i was just reading about the TIPM (fusebox) . I guess it can cause all kinds of weirdness,,,my truck has been acting strange here and there........like trying to stall , wipers turn on by themselves ...now the turn signal
All stuff you mention are things I have seen with the box.
If you swap it out..make sure it is from the same year truck, there are differences between years generally.
Bet a dime to a doughnut you have a fuse box corrosion issue. Extremely common. Hopefully you can find a good used one.
https://repairpal.com/tipm-issues-138
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight
418 BPE factory replacement headed stroker, 565 lift solid cam
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
