Originally Posted by GarageDodge
I'ts the board that the bulbs are plugged into,common problem,might be able to clean the prongs where bulb is plugged it.
That's what it was on my 2004 with the same problem. New board was only like $20. I'm not sure sure how it works to know there's a burnt out bulb but that could be why it's seeing 8V. Did you try pulling apart the other side to see what it does?
