Well. Thanks for all the help guys and suggestion. The ebay NOSR one may not work any better than the old one I have. I hate to pay that much for old rubber. They would all work if not for the gear vendor installation. He just ordered on off of Amazon. It’s a poly from energy suspension. I can modify the cross member. The problem I hate modify if for this junky made rubber mount. The one I got months ago was better than these two. I’ll post the final solution. I may try another attempt to modify this mount. I just put too much ͏H͏e͏at at one time. I knew better. This new mount is not even wide enough to fill up the space like the old old either.
