Originally Posted by Sammy
You're going to need 1 shim. I had the same problem.
If I add a shim, the starter pinion doesn't reach full engagement on the ring gear. I think I'm OK on clearance front to back as I have ~0.100" between the pinion and ring gear when it's fully retracted.
